Shackle flip
koch68
Shackle flip
Post by koch68 »
I am wondering if flipping the rear shackle and re mounting it in the same bolt holes if the bed will still sit down on the frame. It looks like the shackle would be to high. I do not want any sort of body lift either. Just need about 2-3 inches of rear lift.
Taylor-
1968 F250 Highboy np435 dana 24 4.10's
cep62
Re: Shackle flip
Post by cep62 »
Your best bet for a couple of inches is either a spacer block with longer U bolts ,or an "add a leaf."
four wheel drives come with a lift block from the factory and you can safely add another 2 inch spacer.
koch68
Re: Shackle flip
Post by koch68 »
I thought about add a leafs but didnt want to stiffen tge ride any more then it allready is. I think im gunna grt the skyjacker rear 4 inch springs delete the block and use a 2 inch or 3 inch block to level to my front
Taylor-
cep62
Re: Shackle flip
Post by cep62 »
Spacer blocks aren't considered safe on the front axle , supposedly they get loose and can affect steering.
koch68
Re: Shackle flip
Post by koch68 »
I meant block in the rear.my front has super duty springs and is about 3 inches taller then stock
Taylor-
cep62
Re: Shackle flip
Post by cep62 »
That should work fine.
How do the Super Duty springs fit ?
briansbronco
Re: Shackle flip
Post by briansbronco »
Sorry to drag this one back out but could you be more specific on the "super duty springs"? What years are you using on the front?
1970 F250 4x4 SC Flatbed.
1968 F350 DRW Service body.
1969 F250 4x4 SC DRW
"People sleep peaceably in their beds at night because rough men stand ready to do evil on their behalf"---Orwell
Manny
Re: Shackle flip
Post by Manny »
briansbronco wrote:Sorry to drag this one back out but could you be more specific on the "super duty springs"? What years are you using on the front?
Try here Brian if it is brian.... Ryan gave information overload here.....
http://www.fordification.com/forum/view ... hp?t=59497
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
