template for front speaker replacement?
I'm working on getting things gathered up for a stereo replacement. I have the Volvo mount kit, the receiver unit... working on speakers now. I was thinking of replacing the 1 front speaker under the grille with something like 2 4" speakers... anybody have a template to mount the speakers to and just install the whole assembly? For the rear I was just going to install 2 6x9 4 ways in boxes and rest them on the gas tank behind the seat... thoughts on this setup?
- jzjames
Re: template for front speaker replacement?
I'm not up on sound system speaker placement in vehicles, but for our trucks I would think a high up rear speaker set up would sound better than directly behind your back on top of the gas tank.
I went old school for my 67 and just replaced the front dash speaker with the closest sized modern speaker I could find, had to adjust the mounting of it a little, but not much. I think I used zip ties to mount under the dash pad. The mounting holes were pretty close etc.
Sounds good and like I said "old school style" for an old truck.
Our trucks are on the loud side in the cab unless you've got a lot of tricked out sound deadening in there.
- Chaseman
that's exactly what I did , my two 4 inch speakers mount right up where the old single did. Same mounts and everything. No template though , I made a frame for the 2 four inch speakers and used the original arms on the old speakers mount. I might have pics , lemme look.
I'd be interested in pics of that. I just picked up a 69 F250 with no radio or speaker. I took a look under the dash and I assume I'm missing something for mounting of the speaker. I'm just going with a simple dual coil speaker from LMC and a retrosound radio because I'm not keen on cutting into the doors or fabbing up a speaker enclosure. I'm also not sure if I want to drop the coin on one of those Highliner headliners just yet.
Ed
Ed
1969 F250, 360 cid, 4 speed. "Big Red Stump Puller"
1965 Volkswagen 11-Window Microbus. 1600cc.
2014 Jeep JK Unlimited.
- almostcopied
I found a direct replacement "stereo" speaker on LMC. It fit right in. all the holes lined up and now I have stereo in my 72. The sound bounces off the windshield and I can hear better than ever. I am now removing speakers behind seats and 6 x 9 in the doors. I also used the volvo Din kit as was suggested here on another post. Worked great and looks nice. I really appreciate the forums here.
It's all just a bunch of tree huggin' hippie crap!
- colnago
In my '67, the previous owner had cut holes in the kick panels in front of the doors. I replaced the speakers with something newer. It sounds pretty good unless I go faster than 45. With the 4.10 rear end, it gets a bit noisy in the cab if I go faster. The best thing is, I didn’t have to spend a lot of money to get a high-end stereo.
Joseph
Joseph
What part # on that direct replacement stereo speaker
