Brake & Clutch pedal assembly - 1967 F100
eyezuk
Post by eyezuk »
The 2 side bushings and bracket are worn out on my brake and clutch assembly. javascript:emoticon(':cry:')
Crying The brake and clutch are floppy. I thought I could use the assembly out of my 65 f100 parts truck, but it does not fit my 67 f100. Does anyone know where I can find a brake and clutch assembly for a 1967 f100 without paying an arm and leg? Thanks!
1967 Ford F100 (352 SWB 2WD)
i seen one in the junk yard but they weren't from a 67. one of them might have been.
re: Brake & Clutch pedal assembly - 1967 F100
Those are a one-year-only item...however, the assembly from a '68-'72 will bolt right up. Of course, you'd have to also use a matching master cylinder.
390Nut
Post by 390Nut »
Or you could just send the whole assembly to this guy, Mustang Steve, and for about $80 he'll rebuild the assembly with ball bearings, which are unlikely to ever wear out.
$40 will get you the kit to do it yourself, but you'll need a welder, or someone who can weld it up for you.
And yes, this works for ANY type clutch linkage, not just the Mustangs (although the bearings may need to be a different size)
Paul
`69 F100 390 4spd driver
eyezuk
Post by eyezuk »
Thanks Keith and Paul! I think I will try Mustang Steve. I already have the assembly apart so some spot welding shouldn't be that tough. I appreciate the info!
flyboy2610
Post by flyboy2610 »
Great link! I think I'll send him mine, too!
