my father has a old bernzomatic torch kit in a metal case. The last time i used it something malfunctioned and flame was shooting everywhere. What part went bad here? i want to repair and update his kit and give it to him for christmas. I already picked up some new flint strikers.
is something inside this brass nozzle bad? or is it the canister?
propane torch issue
Re: propane torch issue
i guess i'm going to buy a fresh can and try to ignite the torch and be ready to hail mary it just in case... process of elimination
that's what i had to do the last time because flame was shooting out everywhere near the screw on nozzle
it seems funny looking back but it definitely was not at the time
- Nitekruizer
Looks like a cool old torch. I doubt the cylinder (tank) is the issue. I would check to make sure that the little orifice isn't in backwards or that it's not missing. I think replacement orifices are still available if it is missing.
390 FE IN A "BUMP" / 383 WEDGE IN A 2 DOOR C-BODY / 351W IN A FULL-SIZE MERCURY / 194 CHEVY 6 IN A DUECE / 2.4 DOHC CHRYSLER IN A PLASTIC BUBBLE (Driver)
thank you. i had no idea what the parts were called in this torch. i located the orifice which is right behind the tip i think. and yes it is clogged. i am going to soak it in gasoline and see what happens. don't have any fine wire. i wonder if someone sells a orifice cleaning kit or a tip cleaning kit... if i can't clean this orifice out i'll attempt to find a replacement by calling bernzomatic.Nitekruizer wrote:Looks like a cool old torch. I doubt the cylinder (tank) is the issue. I would check to make sure that the little orifice isn't in backwards or that it's not missing. I think replacement orifices are still available if it is missing.
it probably didn't help when i sprayed the torch with a fire extinguisher a couple years ago after i hail maried it into a gumball tree while it was shooting flames out the sides of the torch about a foot long. i've been in some hairy situations but my heart beat picks up every time i recall that one.
