Frame flex
dssco
Frame flex
Post by dssco »
Hello! I'm new here. My '69 F100 2wd's steering felt a little loose so while I had an assistant turn the wheel back and forth I noticed the steering gearbox moving. I found the three bolts less than super tight so I retourqed them. This helped alot but I still see the box moving a little. I think it's frame flex and am thinking about welding up a plate to reinforce it. I've never heard of this on a 67-72 Ford truck before, (unlike chevy's that always crack the frames or pull out the bolts.) Anyway, if someone can check theirs for me and let me know if this is normal, (mine has power steering). Thanks!
heep70
Post by heep70 »
HHHmmmm, never heard of this on a Ford. Sorry, I can't help ya on this one. I do have PS but it is on my "Highboy". Hang on and someone here will help ya out.
By the way, stop by the "Welcome Mat" and intro yourself and the your Ford.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
re: Frame flex
I really doubt that you're seeing frame flex in that area. I've never heard of a frame cracking there on a 2WD...the frame is boxed in that location, so it's darn strong. If it was flexing there because of broken welds, it should be obvious. I'd guess that while the box was loose you got some grit/gravel down between the mounting pad and the box. I'd suggest just removing those bolts and pulling the box away from the frame enough to really clean it up, the box and it's mounting pad.
marz68
Post by marz68 »
Hey DSSCO I did see this once on a magazine were the frame was boxed with a 1/4 inch plate because of the flex in the power steering area.
390Nut
re: Frame flex
Post by 390Nut »
I've seen signs of it once before as well, on a `68 F100 parts truck. Steering gear was a bit loose, and looking at the bolts, the metal on the frame where they went through was stretched a bit, and you could see what looked like little dents, almost like they were countersunk. It was the only one I've ever seen like that, so I chalked it up to a bad bit of steel on that particular frame, that was a little softer than normal.
Paul
`69 F100 390 4spd driver
bluef250
Post by bluef250 »
Since the bolts were loose, check to see if the holes in the frame have been wallowed out from the movement. Second, check to see if the bolts are either stretched or are worn (corroded). Be careful about driving truck until you know or solve the problem.
i know of a 86 4x that the frame broke just behind the steering gear. but i think he was giving it h*ll when it broke.
mrung0wa
re: Frame flex
Post by mrung0wa »
You also should consider replacing those 3 bolts w/new grade 8 one's. It's possible that they have lost their tensile strength through age and or over torque/tightening. This occurence in not common under normal situations.
Make sure that the mating surfaces are clean, dry and free of debris.
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
willowbilly3
Post by willowbilly3 »
fordman wrote:i know of a 86 4x that the frame broke just behind the steering gear. but i think he was giving it h*ll when it broke.
I had to fix one of those once that was a theft recovery.
72hiboy4x4
Post by 72hiboy4x4 »
A company I worked for years ago had a mid-80's
F-250 that they loaded with 55 gallon drums of diesel (for the loader on the jobsite).
Got about 1/2 up the logging road, and broke the frame clean in 1/2 right behind the cab.
I have heard those years are not very strong frames.
And to get back on topic, I personally have never seen a frame problem at the steering box on our year truck. but, thats not to say it can't happen!
Jake11
re: Frame flex
Post by Jake11 »
Your pretty observant. Yep, it moves there. The long pitman shaft is
what does it. Solution? Make a cross brace that clamps onto the steering
box at the bottom where the pitman arm comes out and run it accross to
the other framerail. :)
mrung0wa
re: Frame flex
Post by mrung0wa »
:yt: :thup: FYI: Do not use wood (not even oak or maple) as material for the cross brace! :lol: :P
Lawrence
marz68
Post by marz68 »
yeah :lolprev:
Jake11
re: Frame flex
Post by Jake11 »
:lol: Eucalyptus is purty strong
mrung0wa
Post by mrung0wa »
Jake11 wrote::lol: Eucalyptus is purty strong
Yeah, but it has that pungent odor about it!
Hey Keith P. did you get my PM?
Lawrence
