trans swap
trans swap
alright im swaping transmission in my 71 f-100 302 ci and it has a np435 in it now and im installing a 3+1 4 speed toploader and i was trying to figure out if im gonna need a new bellhousign or what not to hook the other trans up
re: trans swap
I was researching using a car-type Toploader a while back on the old forums and asked this same question, and this is what Barry told me:
68F250 wrote:The truck bellhousing is 7/16" deeper than the car bellhousing. This means any FE car manual tranny (Toploader included) will have a problem with it's input nose engaging into the pilot shaft. I have heard of a way around this though. Instead of using an FE tranny, use the small block trannies (Toploader included). They all have a longer input nose and it engages perfectly.
Actually, I think the small block Toploader would be a better match for a truck because it's a wide ratio with a lower 1st compared to the big block Toploader. Plus, the truck bellhousing takes the bigger 11 1/2" clutch compared to the 11" car bell.
(Close ratio) - 2.32 1.69 1.29 1.00
(Wide ratio) - 2.78 1.93 1.35 1.00
