removed the bed floor
- jimmy828
I finally took time to remove the ribbed floor section out of the bed. Good gosh ,i have never seen so many spot welds . The job took 2- 1/2 hours. I planning on installing oak wood back in it's place.
- 67nukeford
Re: removed the bed floor
I'm planning on doing the same. But, I'm going to put the original floor back in, but with some repairs.
- HIO Silver
I need a piece of bed floor for my F250. Could you part with a good piece? About 8.5x11? If so, PM me!jimmy828 wrote:I finally took time to remove the ribbed floor section out of the bed. Good gosh ,i have never seen so many spot welds . The job took 2- 1/2 hours. I planning on installing oak wood back in it's place.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- jimmy828
PM sentHIO Silver wrote:I need a piece of bed floor for my F250. Could you part with a good piece? About 8.5x11? If so, PM me!jimmy828 wrote:I finally took time to remove the ribbed floor section out of the bed. Good gosh ,i have never seen so many spot welds . The job took 2- 1/2 hours. I planning on installing oak wood back in it's place.
- HIO Silver
Thanks Jim!! YOU ROCK.
Here's what I need to replace on my F250. The extra piece will be good to have on-hand because this is the only bad part that is evident. I have not unscrewed the PO's sheet of plywood from the bed so there could be more.
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- jimmy828
maybe this will fix it.HIO Silver wrote:Thanks Jim!! YOU ROCK.
[ Image ]
