Body mount recommendations?
brownac1983
Post by brownac1983 »
Hey guys,
I've replaced the front springs in my 1967 F-250 4x4 and while my front sag is gone, I still notice a bit of driver's side lean to the front end. Upon further investigation, I found that my body mount rubber is shot. I want to replace the body-to-frame rubber on the cab and front end. I've seen a few threads about the LMC and Dennis Carpenter kits working pretty well with minor fitting. How many of you have done this, and what other sources would you recommend? I've been looking at these:
http://broncograveyard.com/bronco/i-230 ... black.html
How much of a job is it? It looks pretty straight-forward. Are there any pitfalls that I should look out for?
Thanks.
-Drew
jimmy828
Re: Body mount recommendations?
Post by jimmy828 »
I purchased mine from DC . Had to purchase longer bolts for back, but that was not a big deal. I think the hardest part will be getting the old out. You might have to cut them out with saws all.
