Rearend Work / Flex-O-Matic Poly Bushings
- Thundercat6870
Working on the latest 68 F-100 I just bought. I started on the rear frame and suspension. Modified some poly bump-stops to fit the Flex-O-Matic bracket. I put a good film of poly grease between the bushing and the V-8 springs.
MADD MODDS Custom Restification & Fabrication
Two 68 F-100 SHB's one 4X4
68 Cougar XR-7
Three 70 Cougars, Two Xr-7's and one Eliminator clone
68 Thunderbird suicide doors W/factory console
87 Thunderbird 289 H.O. MassAir T-5
68 Cougar XR-7
- Thundercat6870
re: Rearend Work / Flex-O-Matic Poly Bushings
I'll probably have to trim a little more off depending where it sits after I load it.
68 Cougar XR-7
68 Cougar XR-7
![Welcome :wel:](./images/smilies/icon_welcome.gif)
That does look good! Yea, it may lower your ride height some.
Steve
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
- Thundercat6870
spartman wrote:Looks good man.
Is your frame painted or powder coated?
I took the bed off first to make it easier and took everything off the frame including the rearend. The I went to Lowes and got some new rustolium paint that your supposed to be able to paint right over rust and it prevents rust from coming back. I wire brushed the rust off anyway to make it look smooth before I painted it. After that dried flat for 24HRS like the can said I painted some regular gloss over it.
68 Cougar XR-7
68 Cougar XR-7
