i-beam bend
1970F250
i-beam bend
Post by 1970F250 »
has any one tryed to bend the i-beams for a lift themselves? my dad wants to try but i dont :?
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
boots
re: i-beam bend
Post by boots »
Are you talking about bending your i-beams after putting lift coils on your front end to correct camber? If you are then I assume you are going to be bending them with heat. I was thinking about doing it before but I was told by alot of people that heat will weaken your I-beams, then I talked to a guy online and he went down to his local shop and the owner (40+ years experience) said that you can make a jig so you get the same bend on both i-beams, use heat, and then put a fire or welding blanket over it and let it cool by itself. I went and chose to drop my i beams instead of bending them. Also, I dont think anyone on the forum has bent their i-beams. I have never actually seen anyone that has done it.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
oldhalftons
Post by oldhalftons »
the art of bending beams (and it is an art) right is pretty much dead :(
there used to be lots of places that did it but independent suspension in everything killed the custom bending of strait axles and our I-beams.
Don't try to do it yourself.
Autofab still does it and their prices are not that bad considering that they do it right. Don't kill yourself in a truck with bent beams that weren't done right.
and lost their temper or worse became brittle.
http://www.autofab.com/
1969 F100 300/4spd power steering, manual brakes
1970F250
Post by 1970F250 »
thanks guys
Steve
oldschoolrods
re: i-beam bend
Post by oldschoolrods »
The shop i work at still bends I-beams, DO NOT use heat and DO NOT try yourself without the proper gauges, the way its done is to use 2 horeshoe like pieces that go over the axle, chain it off then use a porta power.
flyboy2610
re: i-beam bend
Post by flyboy2610 »
And do not try doing something like this with chain purchased at a hardware store. That stuff isn't up to the job. If it snaps under stress it'll hit you before you hear the snap. You MIGHT survive the experience!
Stroked
re: i-beam bend
Post by Stroked »
Ouch!
1963 Galaxie 2-door sedan 260/3-speed
1971 F250 2wd 360/4-speed
1986 Chevy K10 305/auto
Many, many parts vehicles.......
1970F250
Post by 1970F250 »
:yt:
Steve
~X~
re: i-beam bend
Post by ~X~ »
I have been studying I beams for quite awhile and have come up with all kinds of info. Here is what I know: I do know that guys have been heating and dropping straight axles for a long time. When you stretch a Model A axle it decreases the track width, usually about 3/4" to over 1" depending on the axle and the amount of drop you are getting. Most of the old straight axles you find that are dropped started out alot smaller diameter than a ford Twin I Beam. These axles (I Beams) are VERY tough! It takes alot of heat to stretch an axle from one of our trucks. This is a delicate business and not over stretching is very important. So is proper cooling of the metal when done stretching. I really want to use old school hot rod tech and apply it to modern axles. Buying a set of dropped I beams is not on my list of things to do either.And yes, I know these trucks are much heavier than a Model A, I know because i have one of those too! Here are some pics of what I have come up with so far, one pic is of my I beam jig and the other is of a Model A axle being dropped:
~X~
re: i-beam bend
Post by ~X~ »
Now the Model A
~X~
re: i-beam bend
Post by ~X~ »
Some old dropped axles...
~X~
re: i-beam bend
Post by ~X~ »
Now, theres a company in the bay area called MorDrop. The old guy there has been dropping axles there for decades! He quoted me $400 for 4' of drop and $500 for 5' and I know theres a huge liability but it CAN be done. ~X~
460 crew
re: i-beam bend
Post by 460 crew »
So.....I'm sittin here thinkin you could also be bending the other direction and having some lifted I beams that a few members would be interested in :?
heep70
re: i-beam bend
Post by heep70 »
True, but I would wonder how they would hold up if someone went rock hoping?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
460 crew
Post by 460 crew »
Autofabs beams are bent also, but just because their one of the only 2wd lift companies for the older fords dosen't make them the best. My buddy is getting a set of autofab beams and the rest of the kit from a guy used,for my old 95 that he bought from my brother. I'm sure we'll put it to the test, so i'll have to report back after beeing stranded in the desert.... or not hopefully.
