fender fix
- blumule
fender fix
is, or would there be any way to to push or pull in a slightly bowed out fender? its on the passenger side. I want to do this on the truck. truck was painted 2 years ago and i had a little mishap. im afraid ill do more harm taking it off.
- convincor
Re: fender fix
Bowed in or out?
If out, get a couple layers of masking tape over the area. Get a block of wood like a piece of 2x4 to spread the load. Wrap a ratchet strap around, under the frame, over the fender and around the other side of the engine. Use blocking so to make contact with cast parts and not to other sheet metal. Tighten it up till slightly bowed in. Once you let go it's going to spring back some. Just don't over do it.
Bowed in would be a little tougher.... you would need something "U" shaped to reach ip under the fender and be able to pull on. But same idea, using a ratchet strap.
"Still Plays With Trucks"
- blumule
Re: fender fix
may work, ill lookey see . thanks for the idea.
- DCrusher
- Location: Hurst,Texas halfway between Dallas/Fort Worth
Re: fender fix
convincor wrote:Bowed in or out?
WOW Great ideal I have the samething a bowed out fender on the driver side it not noticable until you get down and look down the Bumpside line then you can see it Great. Thanx for the ideal. I've tried using my big a** to try to move it but like you said you need something to spread it over a wide area I guess I just didn't have enough to move it
http://www.hottottyscreations.com
55 F-100
57 Oval VW
68 F-100 3" Dropped Axles & Rear Hanger Flip
88 Dodge Ramcharger
97 F-150 Extended Cab 4" 6" Slammed
55 F-100
57 Oval VW
88 Dodge Ramcharger
