emblem
- heep70
re: emblem
Which emblems? Arn't they secured with a nut on the back side?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
re: emblem
emblems on the both fender "camper special 390". they are bolted on from the back?
- heep70
Yep Check it out and get back with me. I am confused now.
Greg
re: emblem
No, those emblems are just pressed into inserts in the fender. They'll have to be pried out. You can use a thin piece of wood for your screwdriver to pry against to keep from scratching the paint. Don't twist the screwdriver....that WILL cause scratches. Just gently pry, alternating sides and angle, and slowly work it out.
- mk
re: emblem
Check with your local glass shop. They use a flat white plastic stick for prying the rubber around the glass. I've got a couple and they work great on emblems.
mike
mike
