The perfect burnout
crazyace99million
The perfect burnout
Post by crazyace99million »
I was wondering how people do those sweet burnouts in their vehicles. Do they take the brake off the rear, and hold the break while accelerating?, that's my guess. i'm sure most of you know. any hints? :hmm:
Freightrain
Post by Freightrain »
Well, most times I've seen people just powerbrake it. It holds the front well enough that the backs will be ovepowered by engine torque.
With all my vehicles being stick shift, you just wing it and let it fly. Line lock helps.
Bump'n along.
crazyace99million
re: The perfect burnout
doesn't that burn up your brakes as well?
crazyace99million
Freightrain wrote:Well, most times I've seen people just powerbrake it. It holds the front well enough that the backs will be ovepowered by engine torque.
wing it and let it fly?. what's a line lock?, sorry i'm a newb.
GT-Racer
Post by GT-Racer »
In a stick shift, you rev up the motor and let the cltch out all at once. (wing it and let it fly)
Line lock is used primarily in drag racing. It locks your front tires only by shutting off your rear brakes.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
flyboy2610
Re: re: The perfect burnout
Post by flyboy2610 »
crazyace99million wrote:doesn't that burn up your brakes as well?
It ain't too good for them! :lol:
crazyace99million
GT-Racer wrote:In a stick shift, you rev up the motor and let the cltch out all at once. (wing it and let it fly)
awesome thanks. i'l try it on my dad's truck first :wink:
GT-Racer
Post by GT-Racer »
Be warrned You may send u joints flying. attempt at your own risk.
Dad may not be happy with the results. :x
i had a 72 vega once. yea with the aluminum block. i used to do neutral drops in it. i could get a good squeal out of the tires. but it loosed the torqure converter bolts evey time and the next day i'd be tightening them back up again.
shrektruck
Post by shrektruck »
I thought the perfect burnout could smoke a bowl and then still party all night......Uhhhhh wait, I heard that from someone. Yeah man that's it, I heard that somewhere.
Matt
shrektruck
Actually if I was your dad I'd be pissed. Tires are expensive and so's the gas to light em up.
That being said, a little bleach on the tires is the answer to lots of pretty white smoke. Our local ummm, burnout used to do burnouts after flicking a switch wired to a windshield washer pump mounted in the trunk and plumbed to a bottle of bleach and two lines that ran to the wheel wells over the rear tires, then...SMOKE!!
Matt
cdeal28078
Post by cdeal28078 »
A guy at school way back when had the same type system except he used old tranny fluid.
Smoked up the whole student parking lot and had teachers coming from all directions. lol
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Freightrain
Fortunately I was never much for smoke shows....I'm a acceleration junky.
Getting the vehicle to move is better than sitting still!!!
Bump'n along.
shrektruck
Yeah I like going fast. That's what the Kawi's for-100mph in second gear with 4 more to go. I have to slow down to merge with traffic on the I-5.
Smoke's still cool once in a while though.
crazyace99million
shrektruck wrote:Actually if I was your dad I'd be pissed. Tires are expensive and so's the gas to light em up.
good idea, i'll try that!. (on my dad's truck first of cours:) )
