tires, wheels and leveling
randyj68
Post by randyj68 »
Couple of questions.... was the original wheels 14 or 15 inch on the 68 4X2 f100? i'm also wanting to level my truck, wondering the easiest way to drop the rear a couple of inches to level it out. it is a longbed if that matters. Thanks in advance!
"Ashes to ashes, dust to dust, if it wasn't for chevy's our tools would rust".
forrestbump
Re: tires, wheels and leveling
Post by forrestbump »
randyj68 wrote:the original wheels 14 or 15 inch on the 68 4X2 f100?
15" on F100's
randyj68 wrote:wondering the easiest way to drop the rear a couple of inches to level it out. it is a longbed if that matters.
The reason that the rear is higher is when you add a load to your truck, the rear springs will compress which then levels out the truck.
If you're NOT planning on putting a load in your truck, you could remove the bottom leaf spring from the pack. That should lower it by one or two inches.
Larry
randyj68
Post by randyj68 »
Other than a trip to the dump, dont plan on hauling or puliing anything heavy.....removing thr bottom leaf sounds fairly easy, didnt know if it would effect the ride any
forrestbump
It will actually ride smother without the overload spring in it.
Larry
my 68 rides better without the overload spring under it. i may put them back under the truck someday though. if i ever get the truck back home. the overload spring is the flat spring. not a curved one.
randyj68
Post by randyj68 »
Many, many thanks!
mrtleavitt
Post by mrtleavitt »
FYI - I just took out my overload leaf on my '69 F100 yesterday and it dropped the rear end 3/4".
F100builder
Post by F100builder »
mrtleavitt wrote:FYI - I just took out my overload leaf on my '69 F100 yesterday and it dropped the rear end 3/4".
:yt: For the most part, it will only drop it the actual thickness of the leaf itself...maybe another 1/4" or 1/2" depending on how fatigued your leaves are.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
