How to determine backset?
sargentrs
Post by sargentrs »
1970 F100 Sport Custom. When I got my truck it had 235/75-15's on it, stock wheels. I got a set of 265/75-15's on some Dodge 4wd wheels later on, what I have on it now. I really like the way the 265's look on it. I'll be putting some new mags and tires on it when I get through with the build and I was looking at wheel options online. How do you measure backset? Is it from the inside of the wheel mounting surface to the bead surface on the back side? And what was the "standard" factory wheel backset? I'm leaning toward a 265/60-17 tire and want to make sure I've got enough clearance when I pick out wheels. Thanks!
forrestbump
Re: How to determine backset?
Post by forrestbump »
Randy,
I start by placing the tire only (unmounted) in the wheel well to get a visual. With the truck on jack stands, I mark in chalk the tires footprint on the ground where I want it centered.
I than C clamp a yard stick vertically to the brake drum with the bottom of the yard stick touching the ground inside the chalk mark I previously drew. Measure from the edge of the yard stick to the edge of the chalk mark should give you a pretty good idea of back spacing.
It gives me a ball park idea, at best, knowing that my desired back spacing will have to be compromised by what wheels are available and their back spacing. Close is usually good enough.
Larry
i have read on this site. that you measure the back set by measurring from the face of the brake drum to the nearest object that would rub the tire. probably the wheel well of the bed. and that will give you the back set of the tire. when fully inflated mounted on the rim.
sargentrs
Post by sargentrs »
Both good tips. Thanks guys!
BobbyFord
Post by BobbyFord »
You can easily go 5" of backspacing on the rear if you don't get too wild with the tire tread width. I have 325mm of tread width on 10" rims with 5" of backspacing and it cleared the left side but not the right due to rear housing offset. The left side missed clearing by about 3/4"-1".
sargentrs
Post by sargentrs »
Thanks Bobby. What are you running on the front?
BobbyFord
Post by BobbyFord »
sargentrs wrote:Thanks Bobby. What are you running on the front?
I think they're 4" backspace, 15X8, but I'm changing to 15X7, with 3 3/4" backspace.
sargentrs
Post by sargentrs »
That sounds sharp. Thanks, that gives me a ballpark to work with.
sargentrs
Post by sargentrs »
sargentrs
Post by sargentrs »
Good, detailed explanation of wheel terminology a friend found for me. I hate it when a chebbie guy has to explain something to me and says, "I don't know about Ford but on a GM product......." http://www.chevellestuff.com/tech/wheel_offset.htm
