I am changing to disc brakes on a 69 truck and I am not ready to go to power steering yet, I am doing a little at a time. The problem I am having is I haven`t found a pitman arm for my manual steering for the newer style tie rods and drag link. I have found a lot of arms for power steering but none for manual. Also I have read i will have to change the pro. valve also and can I use the same master cylinder? Will i need a brake booster for the disc brakes?
I looked through a lot of the forum pages and found a lot of info but not any pertaining to the pitman arm ordeal. Can anyone help on this?
Thanks from Seminary, MS
pitman arm
Re: pitman arm
for the pitman arm just use your old steerign linkage until you go to power steering. you can use the same master. you have to remove the residual valve in the master where the brake lines goes in at. they did make manual disc brakes. so you dont have to have a booster. but if the donor truck had one. i would get the one off of it and use it.
Re: pitman arm
I tried that but i could not get the old tie rod ends to go through the hole in the spindle far enough to get the cotter pin through the nut. I was scared I was going to crack the spindle hole. Thanks for the info. Any other help would come with a big thanks.
Re: pitman arm
Another question, is there a 72 up manual steering pitman arm available? All I cam seem to find is power steering. Did Ford go to all power steering after 72?
Re: pitman arm
Does anybody on here have a pitman arm for manual 72 up they would sell?
- bigred72
Re: pitman arm
I have one out of a 71 f100 with man. steering, if its what u need you can have it. send me a pm and we can work out the details. heres a couple pics. the one on top is from an outside frame mounted man steering gear from unknown yr(probably 73 on. not sure tho) bottom is from a 71 f100 regular style man. gear box.
with my 72 tie rod end in it(for fun) hope this is what your after.You do not have the required permissions to view the files attached to this post.
Re: pitman arm
Thanks but I have it worked out. Thanks for the trouble of taking the pics and posting them.
- bigred72
Re: pitman arm
Glad to hear you got it worked out. posting pics was no trouble at all.
