Hey yall, reassembling the upper column & steering wheel after installation of a new turn signal switch and contact brush. When the 15/16 nut is fully tight on the steering wheel, I can stick my finger in the crack between the back of the steering wheel and the next piece of the steering column (where the shift indicator and such are located).
What am I missing? This is a 1972 F100, auto trans w/factory PS, PB.
Steering wheel sitting too far off horn contacts
Mike's Maxim: You can never have too many Ford trucks, guns, guitars, storage buildings, tools, old Ford tractors, money, or tolerant & long-suffering wimmen around.
- ForingaMex
Re: Steering wheel sitting too far off horn contacts
Was it that way before you disassembled it? You might find what you need in this thread. http://www.fordification.com/forum/view ... =5&t=48077
By the way,
from north of the border.
By the way,
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
you need to adjust the outer steering column up towards the steering wheel. and then retighten the lower adjuster clamp.
Thanks Fordman, made the adjustment, all is well
- ForingaMex
Your welcome.
-Jake
