Identify Steering Box
I have a ford power steering box. The part number on the main housing is C9TR 8550. On the input shaft housing it has 9ES, C7AR and DIF cast in different places. I want to rebuild it but want to make sure i purchase the correct kit. I disassmebled it and it does not have a bearing race for the sector shaft on the lower end of the box? (many of the kits i have looked at show a bearing race in the rebuild kit in the picture but that may not be the right picture???)I believe its from a mid to late 70's truck but am not for sure. The plate where the aduster screw is: C6AR 3580 A-2 is cast on the outside of that piece. There was no tag on the box when I got it. Any ideas?
68' F-250 Camper Special, 390, power steering, hydroboost
Re: Identify Steering Box
there are only two boxes that will fit our trucks. look at how many botls the top cover has. http://www.fordification.com/tech/image ... s-Ford.jpg
I know it's a sginaw box. I just got confused when looking at rebuild kits becuase there were so many different ones. I got it figured out. thanks for your help.
