power brake conversion, where is the link
soulcrushing71
Post by soulcrushing71 »
I know I have seen a powerbrake conversion on here but I cant find the link!
Re: power brake conversion, where is the link
i have read it somewhere too. i didnt see it in a quick search. in a 68-72 you just get the booster and brackets from a 68-77 1/2 truck and use that. for a 67 you get the brackets for a 67-77 1/2 and get the booster fo ra 67 only. the only other thing you need is the vacuum hose from the intake manifold to the brake booster. and the one way valve that is on the booster. as well dont forget the plastic firewall seal that is between the booster brackets.
ForingaMex
Post by ForingaMex »
Did you mean disk brakes or just power brakes? Is this what you where looking for? http://www.fordification.com/tech/discbrakes01.htm
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
