steering stabilizer mounting
blumule
Post by blumule »
Hey everybody. Ive got a 69 f100 twin i beam 2 wheel drive. at higher speeds my steering seems a little loose and was thinking of a stabilizer.Ive already replaced the shocks and other bushings, i just dont think these dinosaurs were meant for speed.Anyway i cant determine where it would mount.Did they come on any of these trucks in the past ? Im sure its got to mount to the drag link on one end but where on the other?Any help appreciated.
Re: steering stabilizer mounting
the stabilizer you are talking about mounts between the drag link and the radius arm. it is basically a shock that bolts on. it is clamped to the drag link and then a hole is drilled through the radius arm to mount the other end of the shock. my 67 has one on it. here is aol debay picture i saved from a few years ago.
blumule
Post by blumule »
whats the larger bracket for? does this clamp to radius aem ?
it probably is. this doesnt look like what i remember mine looking like. but i could be remembering wrong.
zoomer
Post by zoomer »
I have this kit on my "71. It really helps.
1971 Ford F100 Sport
302 3 on the tree
Revelation 12:11
And they overcame him by the blood of the Lamb, and by the word of their testimony; and they loved not their lives unto the death.
By this I am a Monster to the Monster!!
blumule
Post by blumule »
how did u mount it?
zoomer
Post by zoomer »
blumule wrote:how did u mount it?
One bracket mounts to the drag link and the other mounts to the radius arm. 15 minutes tops to mount it with no directions! :)
302 3 on the tree
Revelation 12:11
blumule
Post by blumule »
im asuming to the passenger side radius arm. Duhhh! lol ! thanks for helping , i just like to get a vague idea before i order one.
kidd68
Post by kidd68 »
Where can I buy one of these kits? I might try one on my 68.
i thought mine mounted to the drivers side radius arm. i need to go check on the truck. i will take a picture of it.
zoomer
Post by zoomer »
fordman wrote:i thought mine mounted to the drivers side radius arm. i need to go check on the truck. i will take a picture of it.
I'm sure you can mount them on either side.
302 3 on the tree
Revelation 12:11
blumule
Post by blumule »
thanks, a pic would help although im sure a diagram will be included with damper. From the look of it , it seems it would be an easier mount from pass side with the longer drag link. whats the shorter link called? trailing arm?
a trailing arm is another word used to describe radius arms. i think the short rod is called the tie bar.
Mancar1
Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Post by Mancar1 »
I had one on my 65 CS, It helped with the manual steering. I would think about any parts store would have one, or could order you one.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
here are pictures of how mine is installed. it looks like it may have been a aftermarket deal and not liek the photos of the ebay auction photo i posted. mine does go to the passenger side. or maybe the guy who installed mine thought he had a better idea to installing this one. sorry abotuthe photo quality. i forgot my camera and all i had was my phone to take pictures with.
