Correct me if I'm wrong please...
White Lightning
Post by White Lightning »
1971 ford F250 only offered disc brakes on the two wheel drive models...correct? I just bought a 4wd that has disc brakes on the front and I wanted to see if it was a factory option. The seller told me it was a factory F350 (it has the emblem on the hood) 4WD single wheel truck. After I got it home and checked the title and the vin on the truck, apparently what I have is a (F26) F250 4WD that has a (F10) F100 2WD cab with a hood that has F350 emblems on it. WOW...guy swears he's known this truck his whole life and thats how it came. :o C'mon man...people never cease to amaze me. Guys, help me out if ya can...thanks :)
Re: Correct me if I'm wrong please...
it is probably a front end swap. check the tag on the front end. then check the frame vin against the title and the door warranty vin plate.
averagef250
Post by averagef250 »
Never ceases to amaze me how many fellows are 213% positive thier highboy came exactly as it is with a 2wd body, aux gas tank, 390, power steering, power brakes and front discs.
White Lightning
Fordman, I think your right because its a dana 44. Pretty sure it was supposed to come with a dana 60
Racer Z
Post by Racer Z »
Dana 60 is a rear unit. Dana 44 is a front unit. And they are commonly paired. Or am I wrong?
White Lightning
not sure myself...I'll have to do some more digging
from what i have read and it isnt much. is that you are lucky if your truck has or came with a dana 60 up front. most were dana 44's.
71highboy
Post by 71highboy »
yes they came with dana 44 front and 60 rear.some do have the hd 44 though :fr:
mlheppl
Post by mlheppl »
Some dent era F250's and all the F350 4X4's came with a dana 60 up front, but I'm not aware of any bump era F250's ever coming with a dana 60 front. Most had the standard dana 44 froont and a few had the heavier gvw dana 44HD. Neither of which had disc brakes. IIRC around 76 is when the dana 44 got it's first set f disc brakes.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
White Lightning
Thank you guys
averagef250
The ONLY bumpside trucks to come with a 60 front axle were special order. These were usually forrest service and oil company crew cab F-250 4x4's. The 60 front may well have only been available in the crewcabs as these are the only ones I have ever seen or heard of. After writing that I know I sound like the 4x4 know it all, but the NW is the 4x4 center of the universe. If it was a unique 4x4 it was probably sold here or ended up here.
The closed knuckle 60 fronts are a glorified Dana 44 HD. The axles are nearly the same (60 shafts are shorter), the hubs are the same. The knuckles are larger though.
