cozadlance2 wrote:What are spring pliers?
There are several types of "spring pliers".
One type is a normal plier with a small spring to keep it normally open or normally closed.
Another type is used for opening springs. This has a hook on each jaw to grab the spring so you can safely open it and install or uninstall the spring. There is also a variant of this type that can close a spring. A "brake spring plier" is based on this concept.
I don't see where either type would be used to replace suspension bushings. I've never found the need.
What you will need is a "coil spring compressor" so you can work on the front end. There are several types.
One type goes inside the coil and grabs the coils. This has a single "bolt".
The other grabs the coils from the outside. There is a "bolt" on each side.
In either case there are hook like fingers that grab the coils. Tighten the bolt and the spring compresses so it can be removed. On the two bolt type, tighten each bolt equal amounts, alternating from bolt to bolt to compress the spring evenly.
The coil springs are under great load. If you are not careful they will go flying and something will break. It might be your finger, arm or head.
Compress the spring before removing the radius arm bolt.
