putting into 4X4
henryford
putting into 4X4
Post by henryford »
For some reason my 74 f250 wont go into 4 wheel drive. I locked in the hubs, put the standard stick in neutral, put the small stick in 4H, put the standard stick back into 1st, pulled out and only the back tires spin!?!? does the same in 4L. what am i missing or doing wrong? need help soon please!
mlheppl
Re: putting into 4X4
Post by mlheppl »
There are several possibilities. Before I started to tear things apart, I would get the truck on a wet/slippery surface and with the truck in 4 high, spin the tires a bit. Don't do a full burn out or anything, just enough gas to break traction some. Have a friend watch the front tires and see if they break loose. If they don't break loose, jack up the front end with the tranny in gear and the transfer case in 4 high or 4 low. spin the front tires by hand. Watch the driveshaft. If the driveshaft turns, then your front differential is OK likely and you likely have a transfer case issue. If the driveshaft does not turn then the problem would be in the front end.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
cep62
Post by cep62 »
it may even be a lock out that is sticky and wont engage the axle.
1971ford
Post by 1971ford »
Or your stock ford lockouts are broken. I know the tabs on my right front factory ford lockout that you turn broke off so I have no 4wd now. Just another option
-Ryan
1972hiboy
Post by 1972hiboy »
Yeah I had problems with my factory hubs the right side wasnt working. What I used to do to check was in the drive way id lock the hubs get underneath and spin the front driveline. if the hubs lock correctly the driveshaft will obviously not spin. if the hub or hubs dont lock right then you will be able to spin the driveline by hand. once you try that then you can go on and figure if your problem is fron the driveline forward or driveline back.just more information from another 4x4 f250 owner. :wink:
Rich
Dont eat yellow snow.....
