Manual brake to power brake conversion
LIVEWIRE
Post by LIVEWIRE »
So I'm looking at swapping over to power brakes on my '68. is it as easy as it sounds? :? Bolt up the power booster and hook in the vacuum line, then put the master cylinder on? Nothing is ever that easy for me LOL. Thanks for any help.
1968 F100 SWB Custom Cab, 360 3 speed 110,000 original miles, 2nd owner
1969 F100 SWB Ranger, family hand-me down in the process of a full frame off restomodification
1966 F100 SWB Custom Cab, 352 3-speed just pulled from a field on 6-9-11 a day before it was gonna be sent to the crusher
Re: Manual brake to power brake conversion
That's it. You don't even have to remove the brake lines from the master cylinder. Just unbolt it from the firewall and brake pedal and carefully pull it back. Pull the pushrod out of the back of the MC (since the booster will have one built in). Install the booster onto the firewall, reattach MC and brake pedal linkage, attach the vacuum hose to a fitting on the intake manifold runner.
LIVEWIRE
Post by LIVEWIRE »
Awesome, Thanks!! :fr:
