which valve to use and where
Re: which valve to use and where
the one that came off the donor truck will work fine.
line locks are actually dot illegal. i would find out why the parking brake doesnt work.
tanusfarms
Post by tanusfarms »
the donor truck was at a wrecking yard and no valve was there so now I need to find one. The brake doesn't work due to when the installed the dump bead the cut the cable and just tied it out of the way. The line lock was on the truck when I bought it.
Greg
Custom Built and modified F250 highboy, custom dump box, Warn model 8274 winch mounted on the 335 lbs front bumper
Image Image
i bet that 4wd is the same as 2wd. and you just need a 73-79 proportioning valve. for the cable i would get anohter one.
tanusfarms
if I go looking at wrecking yards is there anything I should be leary of. as far as to make sure they aren't gunked up
Greg
Image Image
averagef250
Post by averagef250 »
80's ford trucks are plentiful in yards, the prop valves work fine and are newer than the 70's stuff.
tanusfarms
thanks I'll start looking for them. Do you know where I might find replacement parking brake parts?
Greg
Image Image
measure the cut off cable. since your truck is a possible mix of two era's trucks that is probably the best way to figure it out.
tanusfarms
theres no possible about it. it is a mix of 2 eras I have a 1975 chassis with a 1970 cab. I was checking as to where the best place to get the parts for the parking brake that I do need.
Greg
Image Image
