source for flox-o-matic shackle bushings????
madbiker4
Post by madbiker4 »
I need new bushings in the lower shackle ( where it bolts to the frame ) for a flexomatic. I have tried ford, and it's discontinued. LMC, mac's, NPD, and DC don't list anything for flexomatic. I did some research and thought the 4x4 bushing was the same , but it wasn't. I can get the two upper ones no problem, it's just the lower one (The one that's worn out :o ) I can't seem to find anywhere. :help:
1972 f100 ranger xlt, 300 cid I6, Clifford performance 6=8 intake manifold, Holley 600 cfm 4bbl carb, Heddman dual exhaust headers, dual flowmaster mufflers, duraspark II, power disk brakes.
Re: source for flox-o-matic shackle bushings????
madbiker4
Post by madbiker4 »
they don't list it for the f100, only for f250. unless the 250 uses the same bushing as the 100 and they just don't list it as fitting both?
from what i remember readign on the site. the flex o matic sprign is a F250 spring. and were used on the F100's so it is likely the bushings are the same.
