How much Drop do i need?
- ddunaway
I am planning on doing the Crown Vic IFS mod and would like to hear your suggestions for lowering the rear.
67 F100
31 Ford Model A
31 Ford Model A
- ddunaway
Re: How much Drop do i need?
What, nobody???? Any of you that have done the crown Vic mod please help.
67 F100
31 Ford Model A
31 Ford Model A
- marz68
- ddunaway
Thanks Marz68. i have been watching your Link postings with interest. If I do a flip wont i still need to lower the leaf mounts an inc or so?
67 F100
31 Ford Model A
31 Ford Model A
- quantumleap
go to pep boys and get their leaf mount lowering brackets...like 30 bucks i think...or be one of the first to jump on a set of marz's link setup
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
- ddunaway
quantumleap, Sorry to say i don't have a PepBoys near me and my attempts to look it up on line failed. Do yo have a better name or part number? I am close to being done with the CV front so i think i will be looking into building a c-notch for the back and doing a flip. not sure if i will also need to lower the leaf hanger in the front also.
67 F100
31 Ford Model A
31 Ford Model A
- tybob81
Just flip the rear axle. It will give you around 6" of drop, no need to mess with the hanger brackets.
- tybob81
I have the flex-o-matic rear leafs and a flip. Drop is perfect and no need for a c notch. You can notch it tho if you plan on haulin something. I haven't bottomed out, so I'm going to only do it when I bag it. All you need is leaf spring pad mounts for a 3" axle tube and a pinion angle finder. Don't mess with the drop kits from other companies as they never have the pinion set right and usualy have to shim them. Just set up pinion angle and weld them up. You can cut your old ones off later if you want.
- quantumleap
do you have pictures of your axle flip?
- ddunaway
tybob81, just what i was looking for. I would also love to see pics if you've got them.
67 F100
31 Ford Model A
31 Ford Model A
- quantumleap
tybob, im assuming your running a crown vic front end?
- tybob81
Not on my 68... As of yet. I had done the swap on a 69 lwb I had for a "stress remover". I sold it about a year ago. Thats how I set that one up. Flip and CV front. Had bulit style 18x10 out back on redrilled axles and Torino drums. and 18x8 in front.
- quantumleap
how are you dropped up front to match the axle flip? or is your current truck not lowered
- tybob81
My 68 is beams and coils up front.
- quantumleap
how did you get the front low enough to accomodate the rear being dropped 6 inches?
