F 350 Shocks
- bluef250
F 350 Shocks
What shocks are you running on the rear of your F350? Do you have shocks? And lastly, are all F350 bumps equipped with Dana 70's?
Re: F 350 Shocks
I run Napa shocks on my F-250 and would if I had a 350 as well.
They have shocks and you will want them as well.
From everything I have seen they only came with Dana 70s.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
68 Mercury Monteray
- basketcase0302
Re: F 350 Shocks
BlueF250,
Here's my "shocks" on my F-350 DRW:
http://i240.photobucket.com/albums/ff13 ... job013.jpg
It seems that Ford didn't think we'd need shocks on the DRW trucks, not even brackets there. Our DRW's are kind of like a pogo stick on steroids with no shocks, real...rough ride with no load on the truck!
Steve (Flatbedford) did find a set of shock mounts for his though.
- bluef250
Re: F 350 Shocks
That is quite a build backetcase302. I enjoyed the slide show. Great idea on doing the rear receiver. How much additional work to make the receiver a 3rd brake light? I would think that you would need to run a dedicated brake light from under the dash.
Did Ford install stocks on the SRW F350, such as a crew?
- basketcase0302
Re: F 350 Shocks
Thanks for the compliment!
I believe Steve got his mounts from Ryan (71Ford) here on the site, (from a SRW F-350) ?
Maybe someone else with a little more knowledge on the mounts will pipe in.
- FLATBEDFORD
Re: F 350 Shocks
The rear shocks were optional back then. This is what the factory mounts look like installed.
Here are the ones that Ryan found for me.
It took me a few years to find a set. I haven't installed them yet because I will need longer U-bolts and those will come when I have the rear springs re arched.
Another route you can go with is these mounts from an 80-86 F350 with Sterling 10.25 rear. They may be on newer ones too. They bolt onto the axle with U-bolts around the tube.
The upper mounts are the same from '67-'97 3/4 and 1 ton trucks. You will have to modify one hole to get 80-86 upper mounts to bolt up to a 67-72 frame.
Steve
My Photo Gallery
My Photo Gallery
- Bumpside Collector
Re: F 350 Shocks
Wow! I haven't even thought about shocks on the back of my F-350. I'll have to go look now.
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
2007 F-150 XLT Supercrew 4.6 Auto
1972 F-350 Flatbed 360 2V 4 speed
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
1972 F-100 Ranger XLT long Bed
1972 F-350 Really long dump flatbed parts truck
1981 F-250 Custom Long Bed (Parting out now)
