Front panhard bar/ Lift question
67nukeford
Post by 67nukeford »
Hey all, just got the front suspension back together on my 67 last night. Went to install the panhard bar, and I've found that it's way off. Now, I'm using 2" lift springs, so I'm assuming I may have to either get a new bar, or have my lengthened out.
Any info you can provide would be great, thanks! :fr:
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
Re: Front panhard bar/ Lift question
what is a panhard bar?
ScreaminZ
Post by ScreaminZ »
Panhard bar is used to center the axle under the chassis. Also called a track bar.
Are you sure the axle is centered under the truck? If not, you can use a ratchet strap to center it up. Any lift would benefit from a longer panhard bar or drop bracket, simply because the geometry has changed. I wouldn't think that only 2 inches of lift would have that big of an effect though.
cep62
Post by cep62 »
Checking your old posts , it looks like you used a '79 disc front end .
If so you need the bar that came with the axle.
67nukeford
I'll probably go with a drop bracket. I really need to get some weight on the front end also, to see where it's going to sit, with the motor,trans, and cab on it.
Pat 1967 F100 4WD
