mid 80 f700 box truck
lostcausemotorsports
Post by lostcausemotorsports »
the motor dosent run and the brakes are locked up is there any way to release them with the motor not able to run
Re: mid 80 f700 box truck
air brakes? yes supply air to the air tank. hydralic brakes yes. pull the truck and see if they will break loose. also look for a micro lock in the cab somewhere and flip the handle. if none of that works you will have to try and remove the drums somehow.
70_F100
Post by 70_F100 »
Does it have air or hydraulic brakes?
i think they are electric i know there not air
70_F100
Post by 70_F100 »
They are DEFINITELY not electric... :doh:
Can you post a picture of the engine? We can tell from that what type of brakes you have.
Bullitt390
Post by Bullitt390 »
If it has air brakes you just use the "jack" screw to release the service brakes spring.
Josh
