72 F350 frame tensile strength?
zakt
Post by zakt »
anyone know the tensile strength of a 72' F350 frame?
1972 Ford F350 crewcab
averagef250
Re: 72 F350 frame tensile strength?
Post by averagef250 »
It's probably A36, A36 has a tensile strength from 58,000 to 80,000 PSI.
zakt
Post by zakt »
how can that be verified?
speed bump
Post by speed bump »
I would actually bet its either ASTM 1020 (people commonly call it A36 but I don't start the train without a jerk)or possibly 1026.
Most stuff that I have broke that is called 1020 or A36 typically yields around 45-50kSI and has an ultimate around 60-75kSI.
To find out for sure you can find a metallurgist to grind it for you if you are really really worried about it. Otherwise I would probably get some 1026 and call it good. It will weld just fine to either 1020 or 1026.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
