Power Brake Boosters
dillon
Post by dillon »
Need help: Will 1984 brake booster work on 1971 f100.
70_F100
Re: Power Brake Boosters
Post by 70_F100 »
NO.
That's twice this question has been asked today... :doh:
http://www.fordification.com/forum/view ... =5&t=50359
dillon
Post by dillon »
Can you make it work................
70_F100
Post by 70_F100 »
You can make anything work with enough money, time and patience...
flyboy2610
Post by flyboy2610 »
70_F100 wrote:You can make anything work with enough money, time and patience...
But by the time you spent that much money, you could have bought a new booster.
70_F100
Post by 70_F100 »
And by the time you finished, you could have probably rebuilt your entire truck...
i seen one from a 90's truck put onto one of our trucks. it isnt on there safely. that is for sure. they drilled new holes int he firewall and brake bracket and put it in. but the problem is that the brake rod is a half moon. it is not a rod with a hole in it. so it cant be botled to the pedal. you have to rig it up and then it can still fall off the brake pedal and then you will have no brakes.
dillon
Post by dillon »
Thanks..........I will take everbodys adivce
70_F100
Post by 70_F100 »
Check ebay or your local pull-a-part.
A booster from any Ford F100-F350 from 68 to 77 will be a bolt-in.
its kind of funny. last week there was a booster with brackets and master on ebay and no one even bought it at 20.00.
