hey guys i found this while browsing the web. a list that some one made up.
Chassis Parts
Pinion Seal, AutoZone Timken #5778
Shackle and Rear Spring Bushings, NAPA 274-6459
Drag Link (1973-79 upgrade), AutoZone Perfect Circle DS-807 (OEM D3TZ-3304-B)
Inner Left Tie Rod (1973-79 upgrade), AutoZone Perfect Circle DS806 (OEM D2TZ-3A130-B)
Outer Left Tie Rod (1973-79 upgrade), AutoZone Perfect Circle ES413R (OEM D3TZ-3A131-A)
Radius Arm Bushings, AutoZone Perfect Circle FA498 (OEM C7TZ-3B203-A)
Axle Bushings, NAPA
Rear Wheel Cylinders, AutoZone 33627 & 33628
Rear Brake Shoes, AutoZone Albany #55
Carrier Bearing, AutoZone HB88107A
U-Joints, AutoZone 1-0153BF (Front U-joint is stock even though a new AOD yoke was used)
Front Brake Hoses, CarQuest Parts Master F103201 / F103200
Rear Brake Hose, NAPA 36606
Banjo Bolts (for new calipers), FOMOCO 385116-S2
Flexplate (AOD), NAPA 600-5012 AOD Transmission and Torque Converter, Phoenix Hard Parts
Front Shocks, JCWhitney Gabriel Gas Ryder LT 55ZU5415R
Rear Shocks, JCWhitney Gabriel Gas Ryder LT 55ZU5416X
The front brakes, rotors, spindles, wheel bearings, and calipers all came as a set of mostly new parts I purchased on eBay.
list of chassis parts numbers
- 69rangerf100
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
