wheel question
wheel question
hey guys..... can I put polished 17 inch dodge aluminum wheels from an 05' on a high boy ..........if not , why not??????
1972 crew highboy project
1972 crew highboy 12v cummins daily driver
1970 f250 2wd ranger xlt camper special (first car)
1970 f100 lwb 2wd driver quality
1976 highboy driver quality
etc, etc, etc........
Re: wheel question
i know ford changed the lug pattern in 96 and 97 on the newer trucks and went to metric. i have no idea what dodge has done or when they did it. if they even did it.
Re: wheel question
thanks fordman.......anyone else have any info?.......chime in!!!
- ok68crewcab
Re: wheel question
I would check the back spacing also. Some of the newer trucks have way different backspacing than the older ones.
2 Blessed 2 Be Stressed
Re: wheel question
Probably can, you can generally get away with a fair amount of back spacing it seems like on the closed knuckle axles.
Can you test fit the wheels and tires you want before buying them? Of possible do that and make sure that they fit and don't hit anywhere.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
68 Mercury Monteray
- averagef250
Re: wheel question
The bolt pattern is the same, the back spacing will probably look rediculous like everyone else has said, but throw a tapemeasure on it.
The trend for the pas 15 years by automakers has been to increase positive backspacing every couple years to the point where cars are 100% positive now and trucks are getting there.
