79 parts on a 68??
79 parts on a 68??
My F250 is a 68, and I have a line on a 79 F250 parts truck. My question is would the front disk brake setup go onto my 68?
1961 Ford F-100. Chrysler 318, 727.
1968 Ford F-250. 360, 4 speed. 17.34 at 79 mph. SOLD
Re: 79 parts on a 68??
Yep, should bolt right up!
Be sure to use the donor truck's disc-brake combination (proportioning) valve in place of your drum-brake distribution block, and remember that you'll need to use the donor truck's master cylinder, since it'll be different from your drum-brake unit.
use everything except the brake booster. and booster brackets. they wont fit right or fit on your truck with out drilling new holes .
