Lowering the rear end.
RTG_RACING
Post by RTG_RACING »
I have seen where people take the overload spring out of the rear spring pack to lower it a bit. I also hear this makes the rear spring sag. Is it possible to remove a spring from the middle of the pack to lower the read about an inch or so?
Re: Lowering the rear end.
yes you can do that. or both. it depends on how many springs you have in the pack if it will sag them or not. a 5 pack of springs could have 1 removed without problems i would think.
texrodder
Post by texrodder »
Ive pulled overloads out of lots of trucks over the years and never had a sagging problem, and a 1/2 inch to inch
would be a good number to expect pulling the overload.
