brake booster options...
I've got a 69 f100 without power brakes and drum front. I'm about to swap to the disk brakes, but what are my power brake options? I have had a couple other f series trucks from the late 70's and they had the booster mounted strait to the firewall, unlike the hydroboost setup. I don't want the old style setup, can anyone direct me to what to look for?
Re: brake booster options...
If you don't want the stock style booster mounted to the firewall I think you are left with the Hydroboost you mentioned.
I saw a thread on here about it the other day so do a search. I think they are using an Astro Van unit.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
wait... the stock one is at the firewall?? thats all i want. i dont want the hydroboost
i dont know much about the hydroboost. but it also mounts to the firewall. as does the original brake booster do . via the brake booster brackets.
- texrodder
Pretty simple get all the hardware from a 73-79 truck, Here is some info Keith put together.
http://www.fordification.com/tech/clutc ... ackets.htm
http://www.fordification.com/tech/discbrakes01.htm
http://www.fordification.com/tech/Ibeamsspindles.htm
i have found a cache of 67-72 f100 short beds out in the desert and this guy has factory 5 lug disk brakes on two of them. are these the same as the 73-74 front disks? i just don't want to have hard to find parts.
67-72 5 lug F100's never had factory disc brakes on them.
They were probably swapped over sometime in their lives like a lot of us do to our trucks. Measure the lug nut pattern on them. If they are 5x5/12 they are Ford brakes. Did I get the lug pattern right guys?
CRS you know
clint
CRS you know
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
