Five lug with 8 lug donor
Hi I got a good dill on a 75 8 lug truck. Mine is a 5 lug will a 5 lug spindel fit on a 8 lug for a disk swap. Thanks
68 F-100 LB 360
98 f-250 LT 4x4 SB Just sold it. It was a good truck.
- 91Bear
Re: Five lug with 8 lug donor
Thanks for the fast reply. When a 3 year old is hounding you to fix here quad. Prof reading is less important. But still needed. Sorry for the bad post. champdog
68 F-100 LB 360
for only a spindle swap onto your ibeams check this page and see the kin pin size chart. http://www.fordification.com/tech/discbrakes01.htm
- 91Bear
I have friends from Pittsburgh that talk like that. They like the Stillers and the Iggles. No offense meant.champdog wrote:Thanks for the fast reply. When a 3 year old is hounding you to fix here quad. Prof reading is less important. But still needed. Sorry for the bad post. champdog
