Helper spring stands out
Florian
Post by Florian »
Hi!
The helper spring on the driver´s side of my ´71 F100 Custom stands out towards the center of the rear axle. I have to repair this in order to pass the tech test here in Germany.
Here is a picture:
Is there any chance that the helper spring could be moved in it´s original position with a hammer when the spring is unloaded? Or do I have to remove the spring?
Thanks!
Florian
1971 Ford F100, 302cui, 3 on the tree
convincor
Re: Helper spring stands out
Post by convincor »
smack it with a BFH!!!
"Still Plays With Trucks"
yes a hammer is the way to go. you can then buy a strap thing to put over it so it wont move again if you want.
Wes
Post by Wes »
yes smack that spring back inline, then re-torque the u bolts. There aren't any bands needed to hold this spring in place.
Wes
67 F250 High boy
69 Bronco
Florian
Post by Florian »
Smacked it in, worked perfectly well :thup: Thanks!
heviarti
Post by heviarti »
You'll be cruising around listening to Gunter Gabriel in no time.
Florian
Post by Florian »
Haha :lol:
