Hydroboost .... getting started
la1031
Post by la1031 »
Here is the start of my hydro-boost setup:
Sry guys it was off of a 2006 Chev 2500, it was free so probably the first item broken.... :lol:
http://s446.beta.photobucket.com/user/1968F100/library/
1968 F100 Shortbed
302/306 roller, C6 w/shift kit
3.70POSI w/trackbars
Hydro-Boost
Hoping for 13's and looking good doing it !!
Makita Industrial Power Tools
Tools for the long run.
hazelnut
Re: Hydroboost .... getting started
Post by hazelnut »
The price was right, just dont tell anyone what it come off of,,,,,To late the cats out of the bag now :lol:
Jasper1975
Post by Jasper1975 »
are you using the chevy master cylinder or will you use a FMco part. thinking of doing this on the 71 and then I can lose the vacum pump on the cummins
71 cummins power , turbo 400, gear vendor overdrive, F600 dash, dually
averagef250
Post by averagef250 »
I do quite a bit of work to them so I can use Ford masters and bolt it right up. of the bigger smaller things I mill and tap all holes for SAE O-ring or NPT so I can run JIC lines.
steveh
Post by steveh »
Look like a nice and clean install. Did you shorten the rod to the pedal??
I put one in my unit… works good but had to change out that ford / Thompson pump.
Steve
la1031
Post by la1031 »
Steve
I was curious about the pump, I am using the Mustang pump and it was designed to run a rack not a gearbox and Hydro. I dont have it running yet but I wounder if it is going to work.
As to the pedal, it lowered the non braking height of the pedal, but no I did not have to alter the rod to make it go on. I kind of like the lower pedal stance because I am tall and dont like my knee in the dash trying to brake.
1968 F100 Shortbed
Hydro-Boost
steveh
Post by steveh »
I tried to run with the original Thompson pump but did run into some problems there. Lack of strong assist when it was hot but that was mostly a pre existing condition. Put on a Saginaw pump (with a remote reservoir) and that seems to have solved these problems.
The peddle is a bit jerky but I think that is with the hydroboost itself so maybe I need to rebuild it or get another one. it was with bothe pumps
In the end… I’m happy with the set up.
So what type of oil are you guy running in these setups??
Steve
Wes
Post by Wes »
I tried to run the Thomson pump as well. It did fare for the booster but the P/s box needed more. I switched to the Saginaw pump, with a remote reservoir.
Wes
67 F250 High boy
69 Bronco
steveh
Post by steveh »
So what type of oil are you guy running in these setups?? or does it matter?
Steve
la1031
Post by la1031 »
Power steering fluid?
1968 F100 Shortbed
Hydro-Boost
