1971 F100
07dually
1971 F100
Post by 07dually »
I have a question in regards to the gear box on the power steering.If the valve is sticking would that cause the steering wheel to always turn back to the right?
put in a new kit from Discount steering and so far nothing but problems,first the pump they sent me was junk so now a new pump from them and it works but will always pull the wheel back to the right :x
Thanks in advance
convincor
Re: 1971 F100
Post by convincor »
are the hoses hooks up correctly?
The large fitting on the box closest to the firewall should be the return line hooked to the bottom of the pump.
The smaller fitting should be you pressure line hooked the the center of the pump.
"Still Plays With Trucks"
Re: 1971 F100
could it be a stuck relief valve bypassing?
ForingaMex
Re: 1971 F100
Post by ForingaMex »
I don't mean to highjack this thread but I also would love to figure it out. My truck did that, (turned all by itself when parked) and I took the box apart and installed a shim in there. If I had a exploded view of a box I think I could show you but it's been a long time. It still pulls to the right when I'm driving but not as much.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
Re: 1971 F100
ForingaMex
Re: 1971 F100
Thanks fordman,
I don't know what all the parts are called but I'll look it over and see if I remember what I did and hopefully get to the bottom of my problem.
-Jake
