16.5 x 9.75 rims what tires
Roodaddy
Post by Roodaddy »
I'm not smart enough to answer this simple question myself.
Guy is selling AE Eagle Alloy 058 8 bolt truck rims 16.5" x 9.75" 8 bolt for $200. http://www.aewheel.com/eagle_alloy_wheels.cfm?id=23
(still waiting to find out if they are 8 x 6.5")
I have 8.75" x 16.5" rims and tires on the truck now. So are my tires reusable on these rims? (I was thinking "no"). But I have been challenged to find 9.75" x 16.5" tires. 9.5" yes, but not 9.75". If I can't reuse mine, what should I buy?
Thanks guys!
Bill
''72 F350 Crew Cab
'72 Galaxie 850 Camper
Hawkrod
Re: 16.5 x 9.75 rims what tires
Post by Hawkrod »
I think you are confusing rim size with tire size. A 9.50X16.5 tire is not designed to fit a 9.50X16.5 rim. In this case the two numbers are apples and oranges. The first question I would ask is do you really have 8.75X16.5 rims AND tires now? If so it would be very unusual. 9.75 wide rims are the biggest "normal" size 16.5 rim and came stock on some trucks. I think the smallest tire you can run on a 9.75 rim is 33X12.50-16.5 but it has been a while since I had a chart handy. I am running 35X12.50-16.5's on my 9.75X16.5 rims. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Roodaddy
Post by Roodaddy »
So I get the sense the "no" answer is validated.
(I wish I didn't start this...)
''72 F350 Crew Cab
Hawkrod
Post by Hawkrod »
I didn't say no but that is probably the answer. I asked what size tires and rims you really have now? If you 8.75 X 16.5 tires then the widest rim they will fit is 6.75 which is quite a bit shy of the 9.75's you are looking. I looked at a few other tires and I think I was right about a 33 X 12.50 - 16.5 being the smallest tire you can put on a 9.75 X 16.5 fim. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
