I used to have a listing of the last ten active discussions on the left side of the home page. It's disappeared.
Does anyone know what happened?
Douglas
Active Forums on Home Page
Re: Active Forums on Home Page
I had to temporarily remove them on the front page, since the code on the page that called up the latest forum posts was causing some problems trying to access the site's front page. I'll get that code replaced as soon as I can figure out what was causing the problems.
Thanks Keith. Also, many thanks for your efforts on this website. It's the only place I go to learn about bumps on the web. Nothing else is even remotely close. Kudos to you and all that contribute to its operation!FORDification wrote:I had to temporarily remove them on the front page, since the code on the page that called up the latest forum posts was causing some problems trying to access the site's front page. I'll get that code replaced as soon as I can figure out what was causing the problems.
Douglas
