Power Steering whine.
heep70
Post by heep70 »
Anybody else experenced this whine that comes from the PS pump? Is there a fix? I tried a new pump, the whine is still there.
My neighbor found it to be funny to place a slab of cheese on my hood. :roll:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
oldschoolrods
re: Power Steering whine.
Post by oldschoolrods »
Is it when you turn the wheel? driving straight? or just idling?
heep70
Post by heep70 »
Yes, Yes and Yes. More so when it is cold out and turning the wheel.
Greg
cobraF100
Post by cobraF100 »
Are you using "Type F" Tranny Fluid?
Give it a try,it is a "Technicians Bulletin" for Power Steering units
Chris
Never Forget Our Soldiers
heep70
Post by heep70 »
HHhhmmm, I beleave I am using the "F" type fluid. I will have to go out and check the container label.
If not, how do I go about drianing (flushing) out the fluid to replace it with the "F" type?
Thanks, Greg
Greg
MudinMan4x4
Post by MudinMan4x4 »
i've found when trying to drain something without a drain plug the best way is to use the ol' gas syfining trick will do it, of course now they sell pumps for it...
"Gas' Guzzler fer life" "Southern Pride""It's not what you buy it's what you build"
heep70
Post by heep70 »
I thought about disconecting a line, point it into a bucket and fire it up. The refill it
cobraF100, Is there a type F power steering fluid or are you talking about tranny fluild? I know they both work. I just didn't know if there is a type F PS fluid. Right now the stuff I am using does not indacate it is a type F.
Greg
willowbilly3
Post by willowbilly3 »
Typical old Ford noise. Turn up the radio.lol I have the newer style pump on my 72 and after 3 different remans I just kind of tuned out the pump noise. It steers right and don't leak.
willowbilly3
On fluid, not sure of the lubricating propertys but the designated P/S fluid is supposed to take more heat. I haven't noticed any difference that way but the type F seems to entrap air worse as in foam up. Try bleeding the air out. Do this by starting the engine and turning the wheels all the way to the stop. Shut off the engine and leave it for 10-15 minutes, repeat in the opposite direction. It helps if it is warmed up.
In real cold weather either type is like mayonaise. For cold weather I used the Mecedes-Benze extreme temp stuff as it was the only one I found that would come out of the bottle in.
heep70
Post by heep70 »
Yes, I have been pretty much excepting the whine noise for over a year now. I bled it when I did the power steering conversion, so I am thinking :hmm: the air is out by now :? . Seems my old 72 did the same thing. I just thought I would throw my whine (problem) out there and see if anyone has came up with a fix yet. Thanks for the input. I know now that I am one of many. Greg
Greg
prostreetf100
Post by prostreetf100 »
i have a 72 f250 and a 71 & 72 f100 that do not have the whine in them. lucky i guess. i sell a product called tri-bolon. it is a metal conditioner that many people have put in their power steering pumps with great success with noise. all it take is a couple ounces per quart and can also be used in engines, transmissions and differentials. if you are interested you could give me a call. i have a shop in marysville washington. my number is 360-653-7284. or e-mail me at billscustom@verizon.net.
prostreetf100
sorry! i wasnt trying to sell to everyone just wanted to let him know that i am local and have some in stock. i only buy it buy the gallon. the name of the company that manufactures it is call savalon inc. their phone number is 1-800-savalon. their adress is p.o. box 35722 canton ohio 44735. hope this helps.
heep70
Post by heep70 »
prostreetf100, emailed ya. Greg
Greg
When I was in the Army, I was driving a rusted-out and barely-running '67 Mustang coupe. The power steering pump on it was going out and whining like that all the time. Actually had somebody ask me once if the car was a sleeper and I was running a supercharger under the hood! :lol: :lol:
heep70
Post by heep70 »
It takes all kind (people) to make the world turn.
Greg
