finally found my 8" wheels
ezernut9mm
Post by ezernut9mm »
about time too. i've been looking forever.
i got two small hole wheels:
and three big hole wheels:
Re: finally found my 8" wheels
whee did you get those from?
basketcase0302
Post by basketcase0302 »
Sandblasting & powdercoating them?
ezernut9mm
fordman wrote:whee did you get those from?
guy out in topeka had them.
basketcase0302 wrote:Sandblasting & powdercoating them?
probably. i'm half tempted to use the two white ones like they are. but yeah, i'll probably get them blasted and coated.
cep62
Post by cep62 »
Those look like older wheels ,
I'd check for disc brake clearance and run out before blasting and painting. :2cents:
ezernut9mm
cep62 wrote:Those look like older wheels ,
i am only using two for the back and they will be on my 66. no clearance issues there. thanks for the heads up though.
