sway bar setups
70SportCustom
sway bar setups
Post by 70SportCustom »
has anyone had sucess removing sway bars from something else and installing them on f100 bumps? if so please point me in the right direction. I would like to be able to find something in the junkyard and swap it over.
:D
Re: sway bar setups
73-79 trucks.
AlleyCat
Re: sway bar setups
Post by AlleyCat »
I used the front one from a 76 F250 in my 72. Apart from drilling 4 holes for the frame brackets it was a bolt in. For the rear I scored one from an early 90's F450 SuperDuty but haven't had a chance to work on installing it yet.
Clay
ladykiller
Re: sway bar setups
Post by ladykiller »
I'll probably be using a similar setup as you alleycat. Haven't found the front yet, but I've got a rear bar from a '90 F250 I might try to use. I'll need to fab some mounting pads, similar to leaf spring mounting pads.
'67 F100 360 3-speed
'73 F100 360 c6
'74 F100 302 3-speed
'78 F100 351w c6
'90 F250 351w c6
'92 F150 302 e4od
~all parts trucks~ LOL!
AlleyCat
Re: sway bar setups
Post by AlleyCat »
Ladykiller, you might want to look around for the mounting pads from an 87 -96 F150. Rear sway bars are a pretty common option on these trucks. As far as I know all of them came with the 8.8 rear and the pads are held on with u-bolts. Pins spot welded to the axle tubes keep them from moving. The axle tubes look to be about the same diameter as a 9". I grabbed a set but haven't had time to match them up.
On the bar you have keep in mind that the F250 frame is wider than the frames used on 67 - 72 trucks. The frames on our trucks are 34" wide while that 90 is 37.5" wide. When Ford widened the frames in 73 the F350 ( cab & chassis models not pickups ) and heavier trucks retained the 34" rail spacing to keep in compliance with commercial truck standards.
Clay
ladykiller
Re: sway bar setups
The end links are the key. Look at a set of '90 end links. Spin them 180 degrees and they're just about perfect.
'73 F100 360 c6
'78 F100 351w c6
'90 F250 351w c6
'92 F150 302 e4od
AlleyCat
Re: sway bar setups
Post by AlleyCat »
I'll check them out. Thanks. :)
Clay
Hawkrod
Re: sway bar setups
Post by Hawkrod »
70SportCustom wrote:has anyone had sucess removing sway bars from something else and installing them on f100 bumps? if so please point me in the right direction. I would like to be able to find something in the junkyard and swap it over.
:D
I have a little secret that has made me both happy and a ton of money over the years! Most old Ford chassis mount camper conversions came with aftermarket sway bars because of the body size (it was a nice big kite that moved easily in the wind! LOL). Those chassis are almost always F350's and the sway bars are a direct bolt on for almost any twin I beam truck. I have found them on 65-79 trucks and they are nice great big bars that work great! Later trucks often have factory bars but not always so be sure and check every one at the junkyard. The only part that you have to replace are the clamps around the rear axle and you can get the right size ones at any good auto parts store. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
ladykiller
Re: sway bar setups
Ford vans and ambulances are good targets too.
'73 F100 360 c6
'78 F100 351w c6
'90 F250 351w c6
'92 F150 302 e4od
