hanger flip
hanger flip
Do you need to have the drive shaft cutt when doing this flip?
Re: hanger flip
no. you just adjust the pinion angle fo the rear end. i think soemone said it was 6 degrees. i think that number is wrong. i cant remember.
- td
Re: hanger flip
no your right FORDMAN, i used 2 sets of shims, a 4degree set stacked with some 2 degree's and all vibrations were cured
Re: hanger flip
thanks guys! i have the hangers off and i will drill the new holes tomorrow and put everything back together. i have 4 degrees of shims per side to use i hope this is enough. a buddy of mine tried this flip and said he needed to have the drive shaft cutt, i figured he did something wrong thats why i asked.
Re: hanger flip
td wrote:no your right FORDMAN, i used 2 sets of shims, a 4degree set stacked with some 2 degree's and all vibrations were cured
Where did you purchase the shims at?
Thanks.
- td
Re: hanger flip
summit racing, make sure you order the correct widthshelidude wrote:td wrote:no your right FORDMAN, i used 2 sets of shims, a 4degree set stacked with some 2 degree's and all vibrations were cured
Thanks.
Re: hanger flip
Thanks for the info!td wrote:summit racing, make sure you order the correct widthshelidude wrote:td wrote:no your right FORDMAN, i used 2 sets of shims, a 4degree set stacked with some 2 degree's and all vibrations were cured
Thanks.
Dale
Re: hanger flip
I got my hangers flipped and installed the shims (4dgrees) and the pinion angle was to great so i took one shim out and when i tried putting my leafs plus shim back on the perch i noticed that the pin doesn't line up from the leaf to the perch. I had to move the axle forward about 1.5 to 2 inches to get it lined up correct to the perch. Now my driveshaft is to long. I must have not mounted my hanger correctly I guess, but when I looked at the pic of one on here it was mounted the same way. I used one of the existing holes like in the pic and went from there. What process did yall do when flipping yours so maybe i can figure out what i did wrong? Any help would be great.
- sport71
Re: hanger flip
Dusty's 70 wrote:I got my hangers flipped and installed the shims (4dgrees) and the pinion angle was to great so i took one shim out and when i tried putting my leafs plus shim back on the perch i noticed that the pin doesn't line up from the leaf to the perch. I had to move the axle forward about 1.5 to 2 inches to get it lined up correct to the perch. Now my driveshaft is to long. I must have not mounted my hanger correctly I guess, but when I looked at the pic of one on here it was mounted the same way. I used one of the existing holes like in the pic and went from there. What process did yall do when flipping yours so maybe i can figure out what i did wrong? Any help would be great.
here are some pics of mine, hope they help..
http://www.fordification.com/forum/view ... 15#p377501
Those who do not learn the lessons of history, are doomed to repeat it.
Re: hanger flip
Thanks for all the help, finally got it done. I had a blonde moment and thought I had to much shim but instead didn't have enough. Finished with 8 degrees of shim, thats the most i've heard of any one on here. Pinion angle is right so it must be o.k. Now i will start on the front tomorrow.
Re: hanger flip
What process did you use to know to use 8 degrees? The reason I ask is-I've done the half hanger flip and have 6 degrees in already and still have some drive line vibration.I just used 6 degrees because that's what everyone else was using.I did use a 4 degree first and the vibration was horrible until I installed 2 degrees more and it got better.Maybe I need 2 more degrees? TIA,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
Re: hanger flip
yeah i thought that was alot too. I first started with 2 and worked my way up to 6 and it still wasn't enough so i put 8 in and driveline was straight axle stayed in same location. The only thing I was worried about was my u-bolts not being long enough, but they were just enough. Go for 8 degrees and see if it helps, can't hurt.
