Is this going to work?
OldRedFord
Post by OldRedFord »
I finished with my E-brake cable replacement (finally)
My question is, with all new shoes and drums out back and new cables the threaded rod that is attached to the equalizer bar is a hair too short.
So I went down to Lowes and got a 6" bolt and a 8" bolt. The 6" was a hair too short and the 8" is a half inch too long.
I made a spacer out of two nuts with a larger inside diameter of the bolt, and then used a flat washer and lock washer followed by a nut to take up the slack in the link lines.
If I could find a 7" bolt that would work nicely.
See pic.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Is this going to work?
is this the piece you are dealing with?
knightfire83
Post by knightfire83 »
Should work pretty good. You could also get the appropriate die and add more threads to the 8" bolt.
On mine, I used an old clutch linkage pivot and a section of all thread for that connection.
1970 Ford F250 4x4 ~ Sold.
OldRedFord
fordman wrote:is this the piece you are dealing with?
Yea. The threaded part needs to be longer.
Tim
1971ford
Post by 1971ford »
Looks like it would work great to me.
But what do i know, i tore my e-brake out of the truck :D
Why not try it? I'm guessing you don't have everything together yet?
-Ryan
why does it need to be longer. did you get the wrong lenght cables?
OldRedFord
fordman wrote:why does it need to be longer. did you get the wrong lenght cables?
The cables I got are what NPD had listed for a long bed 1972 F100.
Like the threaded rod needs to be a 1/4 of a inch longer. The end of the threads were even with the cable bracket.
Ryan, it seems like it will work. Its just that I cant move the truck to a hill to test it out. :lol:
Tim
well if the cables are on right then you will have to make something like your doing.
1971ford
Post by 1971ford »
you can do a test that will show if it works or not just by putting it in neutral and pushing. But to test how well it can hold itself you'll need a hill :D
-Ryan
