4x4 steering column
papabug71
4x4 steering column
Post by papabug71 »
Im needing a P/S 4spd. column. I have 2, but they are both in dentside 4x4's. What was the deal with the 4x4 steering columns? I remember something about them being different. I never paid attention to them & I must have robbed the trucks for parts a dozen times each. :doh:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Re: 4x4 steering column
the 4wd column dont have the flange at the bottom of them. they just have splines on the end of the column. i just picked one up from the junk today. it needs rebuilt. it is a auto column.
papabug71
Post by papabug71 »
Craig, by the flange are you talking about the one on the shaft, or the coulmn its self ? I mean, do they have the bearing at the bottom just like a 2wd column?
I have a couple of P/S shafts in the shop I could swap in place of the 4x4 shaft if need be.
Matt
Mine since 5/7/'94
2WD steering columns hook directly to the steering box via the rag joint, and the end of the column shaft has a flange that mates to the rag joint. 4WD columns don't mate to a rag joint, so they have no flange on the end of the shaft. They're splined to accept a U-joint coupler.
papabug71
Post by papabug71 »
Now I remember. So I can just swap a 2wd P/S shaft in & be done with it ??
Matt
Mine since 5/7/'94
Yes. To use a 4WD steering column in a 2WD, you simply need to replace the column shaft with one from a 2WD.
papabug71
Post by papabug71 »
Thanks Keith ! :fr:
Matt
Mine since 5/7/'94
heres a pic of the 79 4wd column and bushing at the end of it.
papabug71
Post by papabug71 »
Thanks for the pic. Im going to pull one of the columns tomm. after thanksgiving.
Matt
Mine since 5/7/'94
