AutoAdjusters
mpuvdd
AutoAdjusters
Post by mpuvdd »
Hello everyone,
I need some help deciding as to whether or not the automatic adjuster in the picture below has the right adjuster lever. It's on a 71 F-250. It's also the front left brake in the picture. It looks to me as if the adjuster lever should be turning the adjuster screw the opposite direction of how it's set up now. It also seems like when I drive the truck I have front brakes for a while but then lose then over the week. Is it possible for the adjuster screw to be threaded wrong and therefore be swaped with the other side??? The brake system is all brand new as well. Thanks a lot
mpuvdd
1971 F250 Custom 4x4 Built 429 w/ NP-435 trani on 35's --- http://www.hatchengine.com
Re: AutoAdjusters
what axle is that front/ rear type? and which side of the truck is that? the adjuster star wheel should line up with the hole in the rear of the backing plate.when you adjust it after it backs off does it tighten them?
m-mman
Re: AutoAdjusters
Post by m-mman »
After a brake is assembled like you show you can always TEST the adjusting mechanism.
Pull the cable back halfway between the guide on the shoe and the hook on the lever.
This will pull the lever away from the star wheel. Then when you release it, does it hit the star wheel and (hopefully) adjust it one click?
Then look to see that when the lever hits the star wheel one click, it it turns the thread such that the adjuster gets LONGER. You want the brake shoes to be forced OUTWARD against the drum by the adjuster mechanism.
If the threads are working to make the adjuster SHORTER you have swapped them from Right to Left.
If the lever doesnt hit the star wheel at all, the cable is too short. The lever should contact about the center of the star wheel.
1969 F-100 Custom Cab 302 T-85 Overdrive, 3.70 equalock & factory 16" wheels
mpuvdd
Re: AutoAdjusters
Post by mpuvdd »
It's a Dana 44 heavy duty and the pic shows the front driver-side one
So, I'm guessing I got the threads flip-flopped with the passenger side brake. Are they really threaded differently?
Re: AutoAdjusters
yes and no. if the threads would be flipped the star wheel wouldnt line up with the adjuster hole on the back of the backing plate.
m-mman
Re: AutoAdjusters
Post by m-mman »
Yes, the adjusters come in both Right and Left handed threads so that the auto adjusters will work properly based on direction of wheel roatation and direction of travel of the adjusting lever.
All MANUAL adjusters are Right handed threads. (and they have the coarse number of star points)
Auto adjuster star wheels have fine numbers of star points.
mpuvdd
Re: AutoAdjusters
Post by mpuvdd »
Dang! Well I guess I must have gotten them reversed...that would make the most sense.
I appreciate the feedback guys, thanks
mpuvdd
Re: AutoAdjusters
Post by mpuvdd »
Just for clarification...they were, in fact, reversed. Each adjuster has either a right-hand or left-hand thread.
